Turn Key and Nothing happens???
Riding P700 and the dash flashed a couple times and then went blank. Engine would not turn over. Pull started it and the screen turned on and ran fine. Battery is 12+ volts. The fuses are fine. Any help would be great.
Is the main fuse in the starter solinoid? A 30 amp fuse? I checked that one and all the others and they are good. The cables are tight and with the key on I moved the cables to see if there was a short or broken cable. If not where is the main fuse located? Thanks!
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
