Piston & Ring replacement????
Old Sep 17, 2009 | 10:15 AM
Marksvilleman10's Avatar
Default Piston & Ring replacement????
I have a 1993 250 2x4 2 stroke. I have never replaced piston and rings on a small engine before. How tough of a job is this? Do I need any special tools? I am leaking oil where the exhaust meets the engine and it seems as if the speed and power is lacking. I am thinking this might be the problem. Any ideas or help would be appreciated.
Old Sep 17, 2009 | 10:26 AM
dirtjunkie's Avatar
Sounds like you have leaky Crankshaft seal unfortunately. While I dont doubt that your top-end may need to be done also.
A top end rebuild is not that difficult, you only need regular metric tools to do it. I would rate it as Medium difficulty. Your repair manual should be able to walk you through most of it.
My 0.02c
Old Sep 17, 2009 | 08:29 PM
Make sure you have the cylinder measured as to size and dont just stick a stock piston and rings back in. Most of the ones I've checked have to be bored at least first over depending on age and wear.
Old Sep 18, 2009 | 10:54 AM
Thanks guys. I will look into this further. What would be a good repair manual to buy for this machine? I found one that is pretty broad. It was a 1985 to 1996 model polaris repair manual. Is there a manual that would be more specific that you would know of?
Thanks
Old Sep 18, 2009 | 01:10 PM
Thanks
The engine basically remained unchanged all these years,just the electronics,stator,etc are different on different models. Just a dependable little 250 that would go for years if maintained properly. I still service some. If its a Clymer manual then its good enough to show you what needs to be done. OPT
robert301972robert
Aug 30, 2015 11:34 AM
toonces
Jul 28, 2015 01:58 PM
ghost civic
Jul 27, 2015 03:15 AM
southbayman
Jul 24, 2015 09:30 AM
clsharky
Jul 13, 2015 02:07 PM
