Using Kerosene as a engine parts cleaner
Old Oct 14, 2009 | 09:57 PM
saby5757's Avatar
Default Using Kerosene as a engine parts cleaner
I bought a Rubicon with a blown tranny so I bought a whole other used engine and swapped it in.
However, I didn't clean the oil tank out very well, and some of the small metal shavings that were from the first blown tranny are backing up my oil filter quite often.
I was wondering if it would be possible and how much harm it would do if I put kerosene in instead of oil, took out the spark plug and turned over the engine a few times just so that i could get the kerosene flowing through the system to clean it out.... then drain and put oil back in....
I was suggested this method, but wanted to get the opinion of a few others to see if anyone has done this before or had a better way to clean an engine out (mainly just the oil tank) without a complete disassembly.
Thanks!
Old Oct 14, 2009 | 10:32 PM
JeffinTD's Avatar
If you've got metal shavings floating around in there, I think you would be better off tearing it down and cleaning it.
I'd also replace the oil cooler.
Old Oct 15, 2009 | 08:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I would not use kerosene. Just get a less expensive but still good quality oil (like Maxima Premium) in a light weight (5W30 if your manual specs it) and a bunch of filters, and just change it all out frequently until the filings go away.
wildbill59
Jun 20, 2015 02:26 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
