check belt light
Old Oct 20, 2009 | 04:54 PM
trailblazermudrunner's Avatar
Exclamation check belt light
hey guys its been a while sence ive been here but i got a queation for u guys my check belt light is on and flashing at 1 to 2 second interviles and i know when it stays on its time for serversing but this is the frist time its dun this to me any help or advise will be amazing i called the shop to night to ask the tech but the shop was closed and said to call back in the morring i just want to see if i can get and idea on what it might be or wat i can do
Old Oct 20, 2009 | 05:28 PM
Hayashi's Avatar
You may find a way to reset the belt light. However, you need to figure out what tripped the light to flash. It's like "check engine" on your car. There is a reason why the light came on. If you just turn off the light without fixing the real problem that caused the light to flash, you are merely putting a bandage on it. First step is to open up the CVT cover and start inspecting the belt and measuring the defletion using proper tool and technique.
Old Oct 20, 2009 | 06:13 PM
ikn i can turn the light off by unplugging and plugging in the plugs into the oppsite ones and i know by turrning it off id be only covering it up i know all this i was woundering wat the repair manual says about the flashing intervils or wat could possible be the problem i guess im just gonna have to take it to the shop and and let them take a look if i cant get ne one to help me out with it
Old Oct 20, 2009 | 08:48 PM
Scottdn's Avatar
I have the same problem. I have a 07 brute. The light comes on and stays on at about 100 hours. It is a reminder to have it serviced. Doesn't mean something is wrong. When the light flashes it means you have a problem. There is a sensor in there that sits off the belt alittle. The light flashes when the belt is moving out enough to hit that sensor. If its flashing I would have it looked at.
Old Oct 20, 2009 | 10:00 PM
well with the p360s when its time for serversing the check belt like stays on steady with no flashes this time its flashing with 1 to 2 second interviles so could the belt be braking down inside and hit the switch the bike runs fine all the way from idle to full throtal
Old Oct 20, 2009 | 10:33 PM
hburg_atver's Avatar
i have also heard that if the battery goes dead it will set the light off. dont know if that is true or not but mine came on at the 100 hr mark as well for servicing.. I checked everything and turned the light off
Old Oct 21, 2009 | 07:26 AM
Scottdn's Avatar
It could be breaking down or it has stretched some and has got loose. Either one of those could cause it to hit that switch causing it to flash.
Old Oct 21, 2009 | 09:43 AM
TLC's Avatar
TLC
P360 650 700 Nyroc's ATV info website
BF 750-650 Nyroc's ATV info website
Old Oct 21, 2009 | 11:06 AM
Hayashi's Avatar
No, you don't have the same problem. Yours comes on and stays on. The OP's light is flashing.
Old Oct 21, 2009 | 11:23 AM
Hayashi's Avatar
There is no such flashing interval 1 to 2 second listed in the manual.
Flashing belt light could mean following:
0.3 sec flashing - Belt switch tripped.
0.5 sec flashing - Memory reading/writing failure on igniter.
