400ex cutting out
Old Oct 23, 2009 | 05:24 PM
leemat97's Avatar
Default 400ex cutting out
I have a 2001 honda 400ex. It does not like to idle because it cuts out and dies. It runs ok most of the time when I am on the throttle, but occassionally it cuts out and misses several times. It automattically backfires anytime I let off the throttle when I am riding.
I first thought it was the coil, so my friend has a 400ex, we swapped the coil, no change. We swapped the rev box, no change. I had an extra stator, swapped it, no change. I changed the oil cause I had gas in the oil, my header pipe glows when it idles. Any ideas?
Old Oct 23, 2009 | 11:24 PM
Kerick's Avatar
dirty carb, jetting, dirty air filter
Old Oct 24, 2009 | 08:01 AM
Loshe191's Avatar
Check your intake rubber make sure there are no cracks or separated spots between the
carb and the head. If it sucks air in it will make it backfire and run a little different.
Old Oct 24, 2009 | 05:03 PM
JeffinTD's Avatar
Ditto what these guys said. It sounds like it is running lean. I'd suspect partly gummed up idle circuit, and also check for intake leak.
Old Oct 25, 2009 | 05:51 PM
leemat97's Avatar
Default leak check
I will check for leaks first, then jump into the carb and see if anything is dirty. I am not able to adjust the idle, no matter what I do it does not make any difference. I will update with a response as soon as I complete the tasks.
Old Oct 25, 2009 | 09:06 PM
storms400ex's Avatar
sounds like a dirty carb more then a air leak
Old Oct 29, 2009 | 07:07 AM
honda450300's Avatar
Try changing the plug, I had an 01 400 as well and I noticed that a lot of them foul a plug really easy and they tend to do weird things sometimes.
Old Nov 29, 2009 | 03:30 PM
jeffs400ex's Avatar
Default Any luck finding the misfire problem?
Just wondered if you found the problem with your 400ex?. I too have the same problem and the carb looks very clean inside.
Jeff
Alex G.
Sep 11, 2017 11:38 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
