2002 trx 250 valves
Old Nov 3, 2009 | 08:23 PM
scorpion 25's Avatar
Default 2002 trx 250 valves
I have a 2002 trx 250 with a possible stuck valve due to bad gas and being sitting without draining the gas. How can I check the valve condition? Is there access to the valve? (like valve cover) How can I unstick the valve?
Thanx for your help
Scorpion 25
Old Nov 3, 2009 | 09:39 PM
Doctorturbo's Avatar
GOT BOOST!
Do a compression or leakdown test.
Should be valve caps or covers on top of the engine to adjust the valves.
You could try to spray some Seafoam on the valve stem and let it drain down between the valve and the stem. It's a good solvent.
Other than that, your going to have to take the head off and clean things up.
Old Nov 6, 2009 | 05:09 PM
TrikeMaster's Avatar
Banned
Good idea. IMO I would take it off to clean it up. You can check every thing else in there also.
95wolv
Sep 27, 2024 12:00 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
