2002 Prairie 400 has me stumped
I have this 2002 Kawasaki Prairie 400 4x4 that I cannot figure out the problem. It starts and idles fine. will rev up in neutral. but when in high or low gear doesn't have all its power. It seems like low 20 MPH is all its got. I checked vavle clearances they are good, the belt looks good, the carb is clean, float height is 17mm which is kawis spec. I tried to richen it with the choke and leaning it out taking off the air filter lid and it doesn't make a difference, the brakes are not sticking, the compression is about 100 psi, I even put a tach on it and it revs up to 7-8 thousand RPM (but kind of slowly). I need to get this atv done a.s.a.p if anyone has any input at all feel free to speak up and it will be greatly appreciated
Thanks
Thanks
I kind of thought that too but the exhaust seems to flow just fine. I am still stumped on this quad it just does not have all of it power???????????????????
I would still check exhast flow, a temporary removal of muffler and see if there is a difference. Check intake maniifold for sucking air in craxks or bad gaskets. Remove cover and see if cvt system is working correctly. Watch clutches to be sure both are working in unision. Let us know what you find.
jrooker6
Apr 23, 2016 07:36 PM
