magneto and transmission fluid
Old Nov 8, 2009 | 02:24 PM
travb35101's Avatar
Default magneto and transmission fluid
any body know how to remove transmission fluid from magneto. i used the wrong fill plug...The manual was so much help...lol quick answers appreciated i have it all apart and its getting dark.
Old Nov 8, 2009 | 04:22 PM
700 sportsman's Avatar
well I'd say your gunna have to take the cover off, and I'd clean it out with brake clean
What year and model bike do you have??
Old Nov 8, 2009 | 07:34 PM
HawkeyeRider's Avatar
CRC makes an electrical cleaner
Wal Mart sell this as well as most auto parts stores
Old Nov 8, 2009 | 07:43 PM
true, I should have been a little more clear, I just meant to clean up the metal parts of the mag. and the inside of the case
that is some pretty neat stuff, I might have to get some of that
Old Nov 8, 2009 | 09:18 PM
travb35101's Avatar
2003 sportsman 700
i took the cover off and cleaned and wiped down the parts as best as i could. do i need to open it all up and use a degreaser. should everthing be completely dry. on a side note... What is there a plug on there for in ther first place .
Old Nov 8, 2009 | 09:32 PM
Yes, you need to open it up and make sure all the oil is out completely and that it is dry. You don't want to burn up your magneto, or worse have the bike catch on fire. The plug is for checking/setting the timing.
Old Nov 8, 2009 | 10:00 PM
travb35101's Avatar
OK WILL DO.. tHANKS FOR THE HELP... I GOT A LITTLE RUSHED AND READ THE MANUAL WRONG. WHICH BRINGS UP ANOTHER POINT.. WHEN I STARTED TO DO ALL THE MAINTENANCE THE FIRST THING ON THE LIST WAS TO CHANGE THE OIL FOR THE FIRST TIME SINCE I HAVE OWNED IT(2 MONTHS). ANYWAY THE OIL DRAIN PLUG WAS STRIPPED OUT BEFORE I EVEN STARTED...SO THAT I COULDNT GET IT OUT... ANY BODY HAVE ANY IDEAS ON HOW TO TO GET IT OUT.
Old Nov 10, 2009 | 05:25 AM
Hmmm, Might wanna start a new thread asking about the stripped drain screw. You'll get a better response. I don't have any advice for removing it.
Old Nov 10, 2009 | 06:06 AM
biggerten's Avatar
I hesitate to ask, but do you realize that the drain plug is removed with a hex wrench and not a socket? There are no external flats on the plug, it is completely round.
Old Nov 10, 2009 | 06:49 PM
travb35101's Avatar
I realize that it is a hex head and there are no external flat edges...unfortunately there were no internal flat edges either. I am going to try and use and easy out unless anybody has any bright ideas before friday.
