05 brute 750 overheating
Old Nov 14, 2009 | 08:28 AM
droptine10's Avatar
Default 05 brute 750 overheating
Radiator is clean, When I ride for 5 minutes or so overheat signal comes on. Fan comes on as well. Coolant is at proper level. The coolant actually starts to boil in the resovouir. Is this a problem with maybe a pump that is supposed to circulate it? Any way to properly diagnose this?
Thanks.
Old Nov 16, 2009 | 11:03 AM
stonny9's Avatar
either the pump or thermostat(should have one)
Old Nov 16, 2009 | 01:49 PM
Hayashi's Avatar
It is my guess that both pump and thermostat are OK on his unit, because his fan thermo switch on the radiator is activating the fan to turn on. If the water pump is not working (ie due to broken rotor) or thermostat is shut closed (ie due to corrosion), hot coolant would not reach the fan switch and the fan would not come on.
I will check three easy things first before getting into more difficult jobs:
> Coolant specific gravity
> Vent spigot on the tank. Make sure it's drill through.
> Vent hose attached to the spigot. Make sure it's not clogged up.
The BF750 has a relatively hot running engine. It's normal operating temp is either at or above normal water boiling pt of 212F. It's important to keep all cooling component in their top shape.
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
ylomnstr
Sep 4, 2015 05:02 PM
