Starting problem... Starter?
Old Nov 19, 2009 | 11:58 PM
Paulram's Avatar
Default Starting problem... Starter?
My 2004 500 has been sitting a few months. Went to start it and all I hear is clicking from the starter. Pull start is fine. Is it the starter? If the battery was weak could the same happen?
Old Nov 22, 2009 | 06:08 PM
NewportHillClimber's Avatar
try chargin ur battery. if it still clicks with full charge then its probably ur solenoid
Old Nov 22, 2009 | 09:53 PM
fredd's Avatar
my moneys on the battery. check the water levels, charge and if that doesn't take care of it, you will probably need a new battery. my '04 just actually did this to me last week after sitting about a month. it starts easy enough with the rope, but I will be getting a fresh battery for the ice fishing season.
Old Nov 23, 2009 | 06:07 PM
swampyjunior's Avatar
I would guess bad battery and or starter selenoid. If the battery is close to 3 years old get a new one.
Don't need the one froma dealer just take the measurements off the old one and note the position of the +/- terminals to how the battery sits in its box. Go to Walmart and find the battery that matches (or as close as you can get) to the size. I think they are like $40 or something and they are about $100 from the dealer.
Charge up the new battery, trickle charge over night, give it a try. If it still does it check the starter selenoid.
SJ
tiresharkdbb
Sep 3, 2017 02:06 AM
clsharky
Jun 8, 2015 11:38 AM
garyt1975
Jun 5, 2015 08:53 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
