My 96 Xpress not firing and electrical help please
Old Nov 22, 2009 | 02:23 PM
keiser blade's Avatar
Default My 96 Xpress not firing and electrical help please
wires cut think these go to oil container
cdi box rats nest
the two empty holes went to the headlight, but no matter what i did the lights wouldnt burn
voltage reg i think
broken coolant temp sens
stator wiring
plug pulled out of case, and one wire skint bare
red wire coming from stator looks like tis going to ground
rigged up key switch
etc, with a twisted up wire
this looks like it goes to like a transister or something, it goes to the back of the bike, also has a ground off the battery that runs back their as well
here they are
crazyness
no spark
thanks brandon
File Type: jpg
Old Nov 22, 2009 | 02:44 PM
first time i tried to start it, it ran for about 30 seconds and quit, now no spark, i think i had to give it throttle
later brandon
Old Nov 22, 2009 | 02:47 PM
ftwflh's Avatar
I have a light switch with wiring and a throttle housing with ETC and wires.Drop PM on what you want
Old Nov 22, 2009 | 04:16 PM
anyone know any ways to test the stator, coil, or the runs switch on the handle bar, could it possible be the voltage reg , im unsure where to start on this thing,
thanks brandon
Old Nov 22, 2009 | 04:39 PM
i hooked up the dash , and have no lights on it at all, so maybe im not getting power from somewhere, could i run a jumper from the battery positive to the circuit board?
i dont have a volt meter to check it
Old Nov 22, 2009 | 05:23 PM
ftwflh's Avatar
Check voltage with a test light.The bulbs could all be blown.They do that when a Bat goes bad
Old Nov 22, 2009 | 05:39 PM
thats what i was doin, i just made one outta a trailer light, and a pick, what i found is that the stator only has 2 wires dimly lighting while cranking, on the etc the cut wire lights up when i touch it, so i know its connecting, when i put the test light on the coil while cranking i get nothing, and one of the other fat wires on the stator dont light up, and neither do the rest of them looks like yellow and yellow/red light dimly while cranking, and yellow brown dosent light at all
thanks brandon
Old Nov 22, 2009 | 05:48 PM
the neutral light on the dash is the only one that dont light the test light, in any position i move the shifter, the brake sensor works, right side of the bike is hot with key on, and the left lights when i pull the brake, so what am i at stator or coil?
thanks brandon
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Elkaholic
Sep 6, 2015 02:44 PM
lancemll88
Sep 6, 2015 03:03 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
lancemll88
Sep 5, 2015 03:16 AM
