700xx cv joint cover on axel came off. help
Old Nov 28, 2009 | 07:48 PM
jscheeler09's Avatar
Default 700xx cv joint cover on axel came off. help
the cv joint cover on my right axel came off today on my 700xx. does anyone know how to fix this? does it take a special tool to put the clip back on the boot? if so, where can i buy this?
Old Nov 29, 2009 | 06:11 AM
HondaMechanic's Avatar
The right side is easilly fixed .. The left side is the drive axle which is a little more work ..
And same as other Hondas the inside boot & joint must be removed to service outside boot ..
Is the boot and band in good shape .. If everything is in good shape clean the grease off the band you'll see there are 2 tabs that hold the band locked , bend out the tabs and lift the band end to make the band a little larger.. Clean all dirt and moisture out of the boot and re-pack with moly-grease ..
Asaran
Oct 8, 2015 11:14 AM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
toonces
Aug 13, 2015 12:40 PM
HondaR24
Jul 16, 2015 10:45 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
