2006 e-ton viper
Old Nov 29, 2009 | 10:14 PM
warrior-435's Avatar
Default 2006 e-ton viper
was sluggish on bottom end but now have much bigger ploblems was riding today and it started spitting and sputering you could hear it cough when it wasn't sputering Ithought it was fouling a plug started home it was cutting out got home changed plug it started poping it back fired really loud now its in the building also before all this it would quit on the trail and would really be hard to start but I thought I cured that when I cleaned the carb
Old Dec 2, 2009 | 08:39 AM
LT80's Avatar
LT80 Expert
you removed both jets and the float needle/seat and cleaned well what's the compression we should eliminate these aspects before going on to a possible electronics issue
not using periods commas and caps sorta sucks to read huh...LMAO
Old Dec 4, 2009 | 06:20 PM
I haven't checked it yet does anyone know what the compression should be
Old Dec 6, 2009 | 08:44 PM
When I pulled the carb I pulled the jets I sprayed carb cleaner threw them and blowed them out with air compressor. They all blowed threw fine. I thought it was probaly electrical because of the back fire. But It probaly does need rebuilt though. It seem to have decent power for a 90 but I'm not sure how much it should have.
Old Dec 7, 2009 | 08:42 AM
LT80's Avatar
LT80 Expert
Comp should be around 110-120
Old Dec 7, 2009 | 10:00 AM
jmracing's Avatar
try unplugging electric choke, if this fixes problem you can leave chock unplugged till needed or replace with manuel chock(can find through dealer and ebay)
Old Dec 7, 2009 | 10:57 AM
rjdad's Avatar
When was the last time that you changed the fuel filter? Make sure all of the fuel lines are flowing free. If you have already done this I do want to apologize. I had to completly disassemble the carb to clean it correctly on my Honda 3 wheeler. The process included soaking some parts, scrubbing onthers with a toothbruss, and even using my air compressor to blow out the passages.
Old Dec 8, 2009 | 11:29 AM
thanx everyone for the help I will post back results may need additional help thax again. I tried to start yesterday wouldn't start didn't have time to check fire or anything had to go to work will try again tommorow
Old Dec 8, 2009 | 11:35 AM
just put a fuel filter on it when I cleaned the carb because I thought the filter was stopped up or it was vaporlocking I thought that I solved them problems maybe it was one thing getting worse I don't know
Old Dec 11, 2009 | 10:45 AM
oldyeller's Avatar
One of the very few problems we have ever had with our viper is the wires going onto the coil..For some reason they tend to get loose after a while and don't make good electrical connection..Take them off and give them a little squeeze with some pliers to tighten them up..Then I like to plug them on and off a couple of times just to make sure there is no corrosion on them...
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
flyin-lowe
Dec 1, 2017 03:18 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
