Fuel Pump for bayou 185
Old Nov 30, 2009 | 10:06 PM
artjtrout's Avatar
Default Fuel Pump for bayou 185
Well now it seems the fuel pump is a problem. I checked some online parts places and the want 140$ for a replacement, Ouch. I checked at Advance Auto and they have an aftermarket pump from Mr Gasket that runs 44$, and puts out 2-3.5 lbs pressure. There is also a Mikuni Pulse Fuel Pump that works off of crank case vacum for 20$ I could hook it to the existing crank case vent and a Facet 12-volt Electric Fuel Pump, 1-1/2 to 3-1/2 psi, 25 GPH Delivery Capacity for 45$ from jcwhitney.com? Any thoughts? Is there a place I can get a re-build kit for the original pump?
Old Dec 19, 2009 | 05:52 PM
Brian H's Avatar
Default Fuel Pump
I am also trying to get an old 185 running. I am in need of a fuel pump as well. Did you come up with a solution? I am curious about the after-market options you had discussed. Let me know what worked for you.
Old Dec 19, 2009 | 07:28 PM
smk8er's Avatar
Try Ebay!
Old Dec 20, 2009 | 12:49 PM
artjtrout's Avatar
I ended up buying a pump from checker auto made by Purolator/Fawcet. It was a 1.5 - 3 lb psi 25 gal per hr. It was $45, sure beats $145.
I made a bracket to fit the existing mount and mounted it output up, input down. Worked great. A 90 degree fitting on the output for clearance made it line up to the carb nice. Ive had it putting around the hose with no problems but not in the field. Good luck!
Old Jan 9, 2010 | 04:27 PM
Brian H's Avatar
I found a used OEM pump on ebay and just took it out for a spin after I stopped a fuel overflow problem. The carb and fuel pump work great.. New problem....it won't downshift out of 3rd gear (i think). Any ideas?
mtdewmn
Jan 19, 2017 12:13 PM
house1
Aug 9, 2015 10:49 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
