2007 trx 450er hot starting issues????
Old Dec 2, 2009 | 10:17 AM
Jeffgaffney's Avatar
Unhappy 2007 trx 450er hot starting issues????
Inhave had this quad for 2 years now and love the power etc. I have an issue with hot starting. I have had my valves done and I still have this issue. I will ride for a while, shut off, and if I try to restart, it will kick over but not start. I have the oil changed often and air filter cleaned each ride. My battery sits on a trickler so I know that is not the issue. I know when it is cold, I sometimes have to drain the bowl but this is when it is hot. Any clues????
Old Dec 2, 2009 | 10:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This carb floods out very easily when hot! Absolutely DO NOT touch the throtle before or during a hot start. It is a pumper carb, and if you thouch the throtle you are injecting a squirt of raw fuel....
Also, it has an automatic decompressor, so you might want to check that it is functioning properly (usually do this at the time of a valve adjustment). Get a service manual if you don't have one.
Old Dec 2, 2009 | 01:25 PM
I did have that checked when the valves were done. I have the HRC kit as well if that makes a difference. I will try without gas but I think I have tried that as well. Any other hints would be great!
Old Dec 2, 2009 | 04:29 PM
Red Rider
I have the HRC kit and the kick starter, and once you have the drill down, it starts first kick every time, hot or stone cold!
When cold, I pump the throtle several times to prime it. Put choke on full, then kick it over and immediately turn the choke down to drop the idle speed. Usually have to baby it for a minute until it warms up.
Hot, I don't touch the throtle, just pull in the hot start button, kick it over, and away we go.....
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
