what chain to use on the scrambler 500?
Old Dec 4, 2009 | 02:41 PM
Flat4awd's Avatar
Default what chain to use on the scrambler 500?
So after 2 tanks of fuel riding it, the chain broke when I took a bump and got airborne. The chain doesn't feel bad, but it's not broken on the master link so that mean it's time for a replacement. Is there any chain that is strong enough? I heard the scrambler damage chain easily.
Old Dec 4, 2009 | 06:04 PM
ftwflh's Avatar
What yr of 500 Scrambler do you have?
I like the DID X or Z chains but you may want to check into a HPD chain tensenor too
Old Dec 4, 2009 | 08:14 PM
Flat4awd's Avatar
2001 scrambler 500 4x4
Old Dec 5, 2009 | 08:28 AM
ftwflh's Avatar
I woul;d do like I said in other post get a X or Z DID chain and the tensinor
Old Dec 6, 2009 | 05:10 PM
Flat4awd's Avatar
do I need the concentric or non-concentric tensionner ?
the chain that broken on me is a Regina Gold O-Ring with large plates (2.2mm). But looking at the sprocket make me thinks that they are worn out. the rear one as been reversed for sure.
Since the front spocket is coaxial with the swingarm, the chain tension do not change with rear suspension movement. I remember reading that the scrambler chain are easy to break. Why ?
I've seen the race-driven-com kit for sale on ebay. then I looked at their website. Are they worth a try ?
Old Dec 6, 2009 | 09:14 PM
ftwflh's Avatar
Yours is a concentric model.And I would replace both sprockets with a new chain.I dont on mine all the time but since you are new to this machine you may as well start off knowing what you have
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
kbazzy
Sep 26, 2015 11:26 AM
exmotocrosser
Sep 26, 2015 08:18 AM
