Brute Force - front end alignment
Old Dec 9, 2009 | 10:47 AM
PolSports's Avatar
Default Brute Force - front end alignment
Anybody have any tips on aligning the front end of a 2006 Brute Force 750.. I have not had much experience on alignment jobs. It pulls to the right bad. I replaced the right front A-arm bearing last night and now it pulls even worse than before since the slack is gone. Any advice???
Thanks!
Old Dec 9, 2009 | 11:34 AM
OGGYDOGGY's Avatar
I have done this to my 08 650 sra Brute . Take the quad put it on level hard surface. Strap handle bars to rear rack, so they dont move with bars straight. Wrap a string around all 4 tires centered with the hub and draw tight, adjust the tie rod so the back of the front tires are about 1/8" in from the string this will give you toe out. There are also other ways to do it like with plates that they use for carts and stock cars but for stuff you just have in your garage this is a good method. Good luck
Old Dec 9, 2009 | 01:46 PM
PolSports's Avatar
Thank you!! Never thought of doing it that way. Will try it tonight!
Old Dec 9, 2009 | 02:46 PM
Hayashi's Avatar
Factory spec in toe-in spec is neutral, 0.0.
If you prefer stability at high speed, set at +1.0 to +2.0 mm (toe-out).
If you prefer sharper/more responsive steering feel, set at -1.0 to -2.0 mm (toe-in).
Old Dec 9, 2009 | 07:01 PM
NewportHillClimber's Avatar
i set all the quads i service at 3/8" toe in
Old Dec 10, 2009 | 08:59 AM
Doctorturbo's Avatar
GOT BOOST!
Toe will not fix a pulling problem. You have other problems.
Old Dec 10, 2009 | 09:21 AM
PolSports's Avatar
Well I just had to measure and "eye ball" it the best I could but got it fixed. I couldn't use the string trick becuase I have aftermarket wheels and tires and the back one stick out farther than the front. I did have a bent tie rod on the right side though and the tire was turned out to the right. Straightened it up, adjusted both sides alittle and runs straight now!!
Old Dec 15, 2009 | 10:43 AM
KMKjr's Avatar
Toe can cause a pull, but steering wheel will be off center and should be noticable.
And check the control arm bushings, they are the normal cause.
Old Dec 15, 2009 | 03:03 PM
Hayashi's Avatar
Why pulling to the right???
Old Dec 15, 2009 | 09:30 PM
GOT BOOST!
How can tow pull to one side if tow is symmetrical? Both tires turn in at the same time (or out at the same time). You can have tow in, tow out or straight up, there is no difference because it symmetrical.
STLyamwar
Jul 25, 2020 04:44 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
