Suzuki LT Z 50 dies when throttle applied
Old Dec 9, 2009 | 01:26 PM
oldstyle's Avatar
Default Suzuki LT Z 50 dies when throttle applied
New to me is a 2006 Suzuki 50 4-stroke.....bike cranks and idles great but bogs or dies after half throttle. I have already cleaned the carb, stripped and soaked etc...I can see through all the jets. The only part that looked like it needed help was the jet needle so it was scrubbed with a ScotchBrite. Air filter and spark arrestor were also cleaned. I tried running without them too.
Plenty of gas is getting to the carb, but I really feel like this is a fuel problem. What would cause a bike to idle well but bog and die as the throttle is mashed?
Old Dec 9, 2009 | 01:32 PM
dal72's Avatar
Default Idles fine, press gas and it kills the motor.
I have the same problem with an artic 50 2 stroke, I have not taken the steps you have yet but am curious what suggestions people have before I dig into it to far.
Old Dec 9, 2009 | 05:53 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
My first thought is the timing might be off. Or a bad/old spark plug?
Not many 4 strokes will take a mashed throttle without dieing...Does it die if you slowly apply throttle?
Old Dec 9, 2009 | 07:04 PM
NewportHillClimber's Avatar
is the gas in the tank fresh?
Old Dec 10, 2009 | 11:47 AM
WAATV's Avatar
Since you've already cleaned the carb (my first recommendation), next I'd check the float adjustment. If it's set improperly, the engine may be starving for fuel at higher throttle settings. The needle+seat (controlled by the float) may be able to supply enough fuel to idle, but when you crank it up a misadjusted float may not be able to supply enough fuel to keep it running.
Report back!
Old Dec 10, 2009 | 12:29 PM
DSengineer's Avatar
Has been here a long time!
Any difference between choke on or off? When cold my sons LTZ50 will usually die if he stabs the throttle too quick. Once it warms up its fine.
Old Dec 10, 2009 | 08:10 PM
oldstyle's Avatar
Problem persists at normal running temp. It doesn't matter how fast the throttle is pressed. Gas is fresh. I'll install a new plug next. Choke on/off doesn't seem to matter. I've sprayed starter fluid into the carb at half throttle and it still flubs.
I wouldn't know how to check the timing, but it does crank easily.
Old Dec 24, 2009 | 02:55 PM
oldstyle's Avatar
I swapped carbs from a Raptor 50 and it did not help. How do I check/set engine timing? The bike calls for 14 BTC.
Old Dec 26, 2009 | 09:54 AM
LT80's Avatar
LT80 Expert
To check the timing, you need to find out where the timing marks are and where they are supposed to align up.
Old Jan 26, 2010 | 03:45 PM
gregg mattison's Avatar
Default Ltz 50
Hey I to have a problem with the kids suzuki. He was ridding it and ran fine we went out on the trails and it started to die and would not throutle up just like you would have the parking brake on and the engine would cut out. I did do the easy stuff like gass and spark. I do think it's in the wiring? Note I can now start this up with out the parking brake set. Can any body help.
