01 rancher need help
Old Dec 14, 2009 | 01:33 PM
rde750's Avatar
Default 01 rancher need help
Will not start at all with the choke. Will start cold only after you prime it. Once started if you pull the choke it dies, so I guess the cable is not broken. Anybody have any ideas how to fix this thing?
Old Dec 15, 2009 | 07:51 AM
79hugger's Avatar
For starters I'd do a plug check and go from there,a plug can tell alot.Any other symptoms after you get it warmed up,how is the idle? I'd start with the simple first, air filter condition,intake boot between carb and head for possible air leaks
Old Dec 15, 2009 | 08:55 AM
rde750's Avatar
Plug good. It idles fine, runs very good. Just hard to start when cold because the choke does not seem to be working.
Old Dec 15, 2009 | 09:06 AM
MUd&ROX's Avatar
how cold is it where u are?
Old Dec 15, 2009 | 09:53 AM
79hugger's Avatar
Could be in need of a choke plunger kit,the o-ring seal on the plunger may be catching air
Old Dec 15, 2009 | 09:54 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
First off, it has a carb heater, so leave the key on for a couple minutes to let it heat up before you try a cold start.
Remove the air filter, and you should be able to look in and see how the choke functions. Cold weather makes you lean (air contains more oxygen), so it should run better with the choke, not worse. Doesn't fit any pattern I am familiar with.....
Old Dec 15, 2009 | 10:29 AM
79hugger's Avatar
The choke plunger is on the left side of the carb where the choke cable goes into the black plastic if not mistaken 14mm screw in fitting followed by a spring and the chock valve plunger which has a outer o-ring,and a rubber seat at the pin seat. Easy to install and common to go bad.Here is a example on a 450ES #9 is the complete choke valve #12 is the heater Ranger spoke of. DiscountHondaParts.com, Honda, Polaris, KTM, Ski-Doo, Motorcycle, ATV,Snowmobile, Parts and Accessories.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
