92 honda 300 fourtrax rearend help
hey i got a 1992 honda 300 fourtrax 4x4 and the rearend is grinding and the tires in the bake dont kick in but the front work. just wondering if anyone get any manaul for it or even some help would be good
thanks
thanks
There are several things it could be,stripped axle slpines,drive shaft,bearings or the ring & pinion.The best thing to do is tear it down.It is not a difficult process.You can get a manual off Ebay,sometimes you can pick up a used one cheap.You can remove the 17mm fill plug on the rear differential and inspect the ring gear teeth for chips or broken teeth by moving the atv forward slow or jack it up so all 4 tires clear the ground in Neutral
