1993 Trail Boss no start
Old Dec 21, 2009 | 03:00 PM
Scott267839's Avatar
Default 1993 Trail Boss no start
Can not get 1993 Trail Boss to start after replacing intake boot. Old boot was split. Cleaned carb already. Help? Getting good spark. Getting a little gas on filter side of Carb????
Old Dec 21, 2009 | 11:54 PM
2006copperspecial's Avatar
Try spraying some fuel into the carb while trying to start, if it still won't start, check the reed valves to see if you might have sucked something in the damaged boot.
Let me know how it turns out.
Thanks
A. J.
2006flhtpi
Old Dec 22, 2009 | 04:58 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hows the compression?
Old Dec 22, 2009 | 06:00 AM
I have tried Starting fluid, no help. No reeds on this.
Have not check compression but it seems strong.-- top end rebuilt last year.
Old Dec 22, 2009 | 06:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you check for good spark? it should at least fired on the starting fluid.
Old Dec 24, 2009 | 12:08 AM
Default Trail Boss
If you have compression and spark and it still won't start, check your crankcase seals.
A. J.
Old Dec 27, 2009 | 02:48 PM
Crankcase seals? I know some people on here has had to replace theirs and it fixed there problem. I just do not understand How/why that causes a problem. I have not work on it the pass several days but plan to look at it some this week.
Will check spark again.
Old Dec 27, 2009 | 02:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
behind the primary clutch is the seals i think he's talking about.
Old Dec 27, 2009 | 04:02 PM
Thanks A.J. and Stendori. I have resurched on here and read about the crankseals and do think they are leaking. Acting just like others that had that problem. But may also have bearing(s) going bad also. Do have some movement (play in one direction)on crank on clutch side. So it looks like I need to take the bottom end apart.
Old Dec 27, 2009 | 06:41 PM
ftwflh's Avatar
Check compression before doing ANYTHING
