tether switch
Old Dec 25, 2009 | 11:52 AM
450r racer #307's Avatar
Angry tether switch
i need help. I had a pro design tether hooked up on my 450r to the key switch and it stopped working awhile ago. so i hooked it up to the ignition coil and it worked the opposite way it was suppose to so when the tether was out it would run and when it was in it wouldn't start. SO now i just got a pro armor tether for Christmas and i also got that kit to hook it up i went out to the barn and tried hooking it up. Now i can't get this one to work either. I have hooked these up before on other bikes why can't i get one to work properly on this 450r? This is just leading to a bunch or aggravation and frustration. thanks in advance
Old Dec 25, 2009 | 12:00 PM
wheily's Avatar
had the same problem with my little brothers 450. i think we had to take it back cause there is two diffrent tipes of teather we had to get one that wires inline to coil and that didnt just ground out. does ur teathers have two wires or just one
Old Dec 26, 2009 | 10:21 PM
two but i found the problem. It wasn't getting a good ground so i was able to use the bolt that bolts the tank to the frame just above the coil thanks for the help.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
