asking some questions about my 06 trx250ex
Old Dec 29, 2009 | 11:41 AM
TRX250EX-PRO's Avatar
Default asking some questions about my 06 trx250ex
Hi, i am new here, I was wondering if you can answer some of my questions:
1. How many pounds of pressure do i put in the tires front/rear(PSI)
2. I am looking to get an exhaust for my ATV, and I've heard you have to re-jet the carb, and something else. What will happen if i don't?
3. If anyone of you guys/girls, have any aftermarket parts for my ATV let me know.
Thankyou!
Old Dec 29, 2009 | 04:36 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There is a plaque on the fender, that gives the recommended pressure if you are running the stock tires. Also can be found in the owner's manual. If you have aftermarket tires, you might start at around 4 psi and then go up and down a little and see what you like best.
A rejet changes the amount of fuel delivered in the carburator. The air/fuel ratio has to be kept at an ideal level. If there is to much fuel for the amount of air, the engine will run bad and dirty ("rich"), but you won't permanently damage the engine. If the amount of fuel is to little, the engine will run hot ("lean"), and you can literally melt your piston! So, when you add more air going in (opening up the airbox) or going out (performance muffler), you will be lean and requiring a rejet.
I would recommend an FMF PowerCore 4 muffler, and a few UNI 1" round vents in the airbox lid (if you don't run in the wet a lot)....and of course that rejet.
Jetting is as much art as it is science. If you aren't up to it, have it done by an experienced pro. http://www.dansmc.com/carbs2.htm
Old Dec 29, 2009 | 10:30 PM
Thanks so much, youve been very helpful, reconranger, and what if i just a put a slip on exhaust on there. do i still have to re-jet the carb? If so, how much do you think the unit and re-jeting the carb in total will cost. Thanks
Old Dec 29, 2009 | 11:06 PM
hi again reconranger. i am also looking to buy Trail Tech Vapor Speedometer Tachometer Computer Honda TRX 250EX TRX250EX 01-06. is that hard to instal? i want to take it to a ATV place. i just dont know how much dough its going to cost.
Old Dec 31, 2009 | 12:22 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
You will still need to rejet with the slip-on for the same reasons Recon mentioned above. Also, get a better air filter. UNI makes a good one.
Typically you will be looking at $60 to $75 an hour for a shop mechanic to do anything, and I will bet money it won't be under 3 hours for a dealer to install it for you (hope I'm wrong)
Old Dec 31, 2009 | 12:45 AM
and how much $ do you think it will be to instal a Trail Tech Vapor Speedometer Tachometer Computer Honda TRX 250EX 2001-2006?
Old Jan 2, 2010 | 04:30 AM
No Ruts, No Glory
Your best bet is to call the dealership to find out
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
