Will parts swap from a 250 4x4 to a 300 4x4
I have a older, say around a 2000 model 300 4x4 that I got in a swap that is in dire need of some suspension parts. I can get for free a little newer (it has the newer wheels on it) 250 4x4 that has a bad motor or tranny (can't remember). These look close to the same. Will suspension parts and cv shafts swap between these two. Thanks in advance.
If the tire and wheel size are the same on both quads you may have something there , my late cousin had both these Suzuki's one was a 1989 Suzuki LT4WD 250 QuadRunner 4x4 and the 1993 Suzuki LT4WD 300 King Quad ; the KQ had larger tires and wheels ( 25x10x12 rear and 25x8x12's front ) the 88' 250 had 25x10x11's and 25x8x11's on front ; you should be able to use most of the part's of either of the two !
williebee.............
