Polaris 90 Brakes Drum
Old Jan 5, 2010 | 05:36 PM
River Hill's Avatar
Default Polaris 90 Brakes Drum
I need to change the rear brakes on my sons 90 and have never done it before. Any tips you can offer or a how to site? The front were easy, but I am not really sure where to start on the rear.
Old Jan 5, 2010 | 09:17 PM
rapple's Avatar
A shop manual is a worthwhile investment if you're planning to do almost anything to that machine. Unfortunately, mine is in storage along with the Polaris...
From memory, you need to remove the right wheel and hub and axle nut.
The axle slides out of the carrier towards the left side and with the brake drum attached, exposing the shoes. If I recall, it's a fairly simple job.
Take a look at the parts fiche over at bikebandit.com. That'll give you a good idea of how things go together.
If yours is anything like ours, you'll find plenty of mud inside there. A few times, I've opened it up planning to change the shoes only to find that a good cleaning is all it needs. If at all possible, replace the rubber seal.. I've re-used ours in a pinch a few times just to get through a weekend, but that just leads to more dirt and wear.
Old Jan 6, 2010 | 09:41 AM
River Hill's Avatar
Thanks for the tips. I am going to replace the pads, as we are going to sell it. My son needs to move up. Any suggestions on where to purchase to rubber seal from?
Old Jan 6, 2010 | 09:42 AM
River Hill's Avatar
Another quick question. The kick starter does not spring back? Any ideas or suggestions?
Old Jan 12, 2010 | 05:52 AM
Bryan55m's Avatar
I also use bikebandit... as they show all the parts and a good idea how it goes together but there are no directions. If you are mechanical incline this should prove to be very helpful.
Reactant
Mar 30, 2022 02:08 AM
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
