360 Prairie Flashing Light 4x4
Old Jan 10, 2010 | 09:27 PM
M38Jeep's Avatar
Default 360 Prairie Flashing Light 4x4
The 4 wheel drive light on my 2007 360 prairie keeps flashing at about every 1/2 second. The 2 wheel drive and 4 wheel drive both work but the light keeps flashing in both modes. Where should i look first. Thanks
Old Jan 10, 2010 | 09:39 PM
rammy's Avatar
i am not going to be any help here but i will say that my brute 750 does the same thing and i posted it on here under "brute force dash flashing" and have had 27 people read it with no replies so good luck on trying to find someone to help you. if i knew the problem i would sure help ya . sorry
Old Jan 10, 2010 | 09:44 PM
M38Jeep's Avatar
Its strange because its runs fine but the light keeps flashing.
Old Jan 10, 2010 | 10:21 PM
rammy's Avatar
well mine has only done it once the day i was plowing alot of snow. maybe snow got packed in some censor or something cause all i did was shut the atv off and waited a minute, started it back up and it hasnt done it since. that was a few days ago.
Old Jan 10, 2010 | 10:29 PM
stillV1's Avatar
Do a search on the topic and i'm sure you find that others have had this happen and you might find the answer in some older posts. I can tell you about the belt light flashing but have had no issues with the 4x4 light flashing
Old Jan 11, 2010 | 09:03 AM
TLC's Avatar
TLC
This what they say for the 700/650. Nyroc's ATV info website
1. If it alternates really fast at .5 seconds on 2wd and .5 seconds on 4wd then the problem is Selectable 2wd/4wd actuator.
2. If it alternates from 2wd/4wd at 1 second intervals, the problem is the Engine Brake Actuator.
3. If it alternates from 2wd/4wd at 2 second intervals, the problem is both the selectable 2wd/4wd actuator and Engine brake actuator.
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
PrairieDog126
Sep 12, 2015 05:23 PM
Steeldon
Sep 9, 2015 09:38 AM
