battery isolator
Old Jan 11, 2010 | 08:25 AM
rickharwood's Avatar
Default battery isolator
I have a 2003 Honda Rubicon. I have mounted a second battery to run my winch. I want to add a battery isolator so that both batteries can be charged. I think I have to cut the red wire coming out of the charging regulator (under the right hand read fender) and connect the regulator end to the centre pole on the battery isolator and the other end of the red wire I cut will be terminated and taped off.
Has anyone ever done this? Is this correct?
Old Jan 12, 2010 | 09:24 AM
ddrumman2004's Avatar
Have you "Googled" battery isolator? Seems there are a couple ways to do this.
Not sure about the charging system on the Rubicon whether or not it would keep both batteries charged if you were to wire them in parallel. If it will, you have the added advantage of the extra current capacity that two 12 volt batteries in parallel would offer.
I doubt it will though being Honda never planned on installing dual batteries on their atvs.
Old Jan 12, 2010 | 01:03 PM
zitaron's Avatar
Yuasa are also doing a high output battery now - so a YTX 20 H should run nearly anything.
Old Jan 12, 2010 | 01:54 PM
Thanks - ya I have done a bit of research - just at the point now of cutting into the wiring harness from the requlator and didn't want to screw it up if it wasn't going to work.
Old Jan 12, 2010 | 01:56 PM
I will check into this - you are suggesting replacing the 14 with a 20 - I wonder if it will fit in the same battery box - there is No extra room in the battery area
Old Jan 13, 2010 | 09:06 AM
MUd&ROX's Avatar
the 20 fits just fine on my rancher...thats the route I went and it runs my bike winch spot light and underbody LEDS just fine....just dont hammer down on the winch like its a throttle and your fine....winch slow and all is good
Old Jan 13, 2010 | 08:54 PM
ok - I will look into it - thanks
pgamboa
Dec 24, 2023 11:52 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
