08 Bayou 250 Clutch ???'s
Old Jan 13, 2010 | 02:26 AM
jc052685's Avatar
Default 08 Bayou 250 Clutch ???'s
Recently got a deal on an 08 bayou 250. only down side is the automatic clutch is starting to slip. Any information on these would be great! I kep seeing clutch kits for sale but they all look like the standard manual clutch pack with disks. Now this has the 5spd manual tranny but its a "clutchless" shift. So is the clutch the same as with a manual tranny just with automatic operation?
Thanks
Jeff
Old Jan 13, 2010 | 08:29 AM
knukey's Avatar
Default There is an
automatic clutch adjustment procedure in your operator's manual. Loosen two bolts holding the adjustment cover on the right side, loosen lock nut, tighten in adjuster all the way in until tight, back out adjuster until tight, tighten lock nut and reinstall the cover. You should NOT have an issue with the clutch on a 2008 model. I doubt you should have problems on a '99 model. Good luck!
Old Jan 13, 2010 | 02:52 PM
jc052685's Avatar
I did noy buy it new. I got is from the security company I work for. It was treated like utter sh*t!!. No one would ever shift down to first. They would start from a dead stop in 2nd or 3rd all the time. That is why I figured the clutch was shot.
I will try to ajust it and see if that helps though.
But hey, only paid $1000, yeah!
Old Jan 13, 2010 | 04:27 PM
jc052685's Avatar
Also any links to a diagram?
Old Jan 14, 2010 | 08:45 PM
reboot's Avatar
I just joined this forum. I have an '08 Bayou 250. You can find a parts diagram on kawasakipartshouse.com I hope this helps.
Old Jan 15, 2010 | 12:16 AM
jc052685's Avatar
Excelent!! Thanks!
Old Jan 15, 2010 | 12:22 AM
jc052685's Avatar
ok, based on this pic do you think it is posible to add a friction plate/disk for more holding power?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
rcappie4
Sep 9, 2015 07:04 PM
