Installing hour meter on Recon
Old Jan 19, 2010 | 09:56 PM
StanD's Avatar
Default Installing hour meter on Recon
I’m in the process of installing an hour meter on a 2007 Honda Recon and found two unused connectors taped up to the main wiring harness along the left side. One is green and is a ground wire, the other is black and tied to the ignition switch ……just what I need, except the connectors are an odd size. They are a smaller diameter that the standard bullet connector available locally. Has anyone used these connections? If so where did you get the appropriate connectors? Thank you
Stan
Old Jan 20, 2010 | 05:02 AM
budedm's Avatar
Hey Stan, Where did you buy the meter? Did you order the tires yet?
Old Jan 20, 2010 | 11:07 AM
StanD's Avatar
Bud
I’ll probably hold off on the tires for a while, at least until I see if my wife is going to use it. The hour meter is a Hobbs digital meter I purchased from NAPA for $33.79. It’s the same one I installed on my Rancher.
Stan
Old Jan 20, 2010 | 12:17 PM
budedm's Avatar
I'll have to head over to NAPA and get one. Good idea to have one. Let me know what you find out about those wires and if they work.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Jazperman
Aug 7, 2016 08:12 PM
panicmanic
Sep 20, 2015 05:54 PM
Hondamx751
Aug 13, 2015 01:06 AM
Hatrackr
Aug 11, 2015 09:03 PM
