new code rancher
Old Jan 20, 2010 | 10:21 PM
pennreels's Avatar
Default new code rancher
This is where I am. I had a code 5. The machine would not start. Now I have cleared the code 5 and my machine starts and runs but will not shift. I now get 2 differant codes. When I turn the key to on I get no code problems. The "N" does not blink. When I push both the up and down bottons I get a code 2. When the machine is running and I use the manual shift I get a CODE 3. The machine now starts with the elec start. Should I disregard the code 2 and go with the code 3 and replace the angle sensor. What do you think?
Tom
Old Jan 21, 2010 | 03:55 AM
HondaMechanic's Avatar
Code #2 is "shift switch system up and down" did you check the left handle bar switch ..?
Old Feb 14, 2010 | 09:06 PM
pwrdzl's Avatar
If you have a meter you can check the switch and the sensor. A Honda service manual has the procedure in there. If the wheeler has a few hours on it or water crossings chances are its the bank angle sensor
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
Sw00p
Sep 24, 2015 02:50 PM
rgjackson
Sep 17, 2015 11:21 AM
patrick.oc123
Sep 15, 2015 02:45 PM
