87 trx350d, no spark or fuel pump
Old Jan 23, 2010 | 01:59 PM
msteve1014's Avatar
Default 87 trx350d, no spark or fuel pump
The quad died the other day, no spark. As I'm looking around I find the 15 amp fuse blown. Replaced it. No help, but it did not blow again. After looking for a while I find I have no power to the fuel pump either. The pump is fine, but is never getting a signal. The pump relay would not keep me from getting spark, but can the cdi kill the signal to the pump relay? Thanks, Mike
Old Jan 23, 2010 | 03:32 PM
HondaMechanic's Avatar
Here are the ignition tests & fuel pump tests
Ignition tests
Fuel pump tests
Old Jan 23, 2010 | 04:45 PM
msteve1014's Avatar
The quad is in Mexico and I am in California now, but I did some testing before we left. The coil looks good. There is no power getting to it. The manual is not really showing a way to test the fuel cut relay, just jump around it and see if the pump works, it does. It seems I am not getting a signal on the bu/y wire, or is it a b/y ?, I can not make it out on my diagram, to the coil and FCR.
Old Jun 30, 2020 | 04:13 PM
cwebbatmc's Avatar
Msteve, I realize this post is ancient and dead. still wanted to ask the outcome because I have the same issue - no spark, no fuel pump activation. Just no fuse blown that I can tell.
SEth22
Feb 12, 2018 07:49 PM
Roto148
Dec 7, 2009 04:40 PM
batholith
Apr 23, 2009 10:05 AM
rhealey
Dec 28, 2008 07:29 AM
cannondale2001
KTM
Feb 5, 2007 05:41 PM
