06 500 Actric Cat
Old Jan 24, 2010 | 06:11 PM
gbynum's Avatar
Default 06 500 Actric Cat
My bike sucked up some water. Drained fuel bowl. Startes fine. Have to press throttle slowly or it will cut out. Plug is black, haven't replaced it yet.
Old Jan 24, 2010 | 08:00 PM
NewportHillClimber's Avatar
you may wanna change the oil and make sure you clean and refresh your air filter
Old Jan 24, 2010 | 08:14 PM
xcitmt's Avatar
Just got the same bike and am wondering how deep you took it before you got water? Or was it just splashing through stuff not so deep. I am not to fond of the MP snorkel, but I guess the intake is right behind the grill. Prob not the best place to put it.
Old Jan 24, 2010 | 11:28 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
definitely change the oil. You may still have some water in the gas, try running an additive to help clear it out. Clean and dry and reoil filter.
Make sure to use Dielectric grease on all your electrical connections, especially your plug wire and ignition
Old Jan 25, 2010 | 10:19 AM
gbynum's Avatar
Default 06 500 Acrtic Cat
Water was 3' more or less. Oil was fine, drained gas and added Heat and octane booster. Waiting for plug to come in to change. Never had any problems with this bike. I backed in water to pull someone else out and mine died. I keep front end up when going thru deep holes.
Old Feb 3, 2010 | 09:43 PM
gbynum's Avatar
Still having problems with my ac 500. Changed the plug and still cuts out on quick throttle responce. Could it be the coil or cid breaking down.
