Rancher 350ES Leaking Gas
Old Jan 24, 2010 | 08:42 PM
Tickledblue's Avatar
Default Rancher 350ES Leaking Gas
My Rancher was leaking gas. I put a new kit in the carb. It still leaks at times. It will start running rough(flooding) sometimes and when I shut it off it will leak all the gas out the overflow tube. This just happens now and then. Can anyone help me with this? thanks
Old Jan 26, 2010 | 10:34 AM
Momule1's Avatar
Question
Did you replace The needle valve and needle valve seat??
does the float rattle or have liquid in it ???
Old Jan 26, 2010 | 10:35 AM
Momule1's Avatar
RESET the float level
Old Jan 26, 2010 | 08:40 PM
JeffinTD's Avatar
Either the float valve is leaking allowing the carb to overflow, or I believe that model has a primer **** and if the rubber piece has cracks in it the float bowl will also overflow.
Old Jan 27, 2010 | 07:00 PM
Default Rancher 350ES leaking gas
Thanks, It is a 2001 model. I don't know of a bulb. I don't think it has one. I replaced the needles etc. with the kit. There is just something causing the float needle to hang sometimes I guess. One small enginge man told me to put fingernail polish around the seat. If it were leaking there it seems it would leak all the time. Thanks
Old Jan 28, 2010 | 03:27 PM
zitaron's Avatar
2001? clean the fuel tank and line completely.
change out the float valve - part number 16155-413-751
stay away from the nail polish - it can work ... then again, it doesn't.
Old Jan 28, 2010 | 09:05 PM
Default Rancher 350Es Leaking Gas
I hadn't thought about cleaning the fuel tank etc.. It did sit for a long time before I got it.
Thanks
Old Feb 3, 2010 | 09:15 PM
watson's Avatar
honda rancher 350es ran fine and then just started running as if carb flooding starts fine and takes throttle until u put it in gear and then it chokes out in about 10 to 20 feet; when stopped, after a few minites it leaks a puddle of gas about size of 2 hub caps out of fuel overflow line (I think, the line comes off bottom of carb) it hasnt been sitting up
Old Feb 4, 2010 | 03:32 AM
Momule1's Avatar
The three most common things to cause this condition.
1. Float level set too high Or binding.
2. Needle Valve or needle valve seat worn.
3. Dirt under needle valve.
Momule1's Avatar
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Clint Russell
Sep 25, 2015 03:20 PM
wrencher82
Sep 24, 2015 03:39 PM
