2004 Sportsman front Diff
Old Jan 25, 2010 | 11:46 AM
sportsman70004's Avatar
Default 2004 Sportsman front Diff
So..another diff thread. 1st time I have had front diff issues...Here is what I have going on. Changed fluid a month ago and checked it again today..still full (yes correct fluid used). I was out plowing and when I back up the 4 wheel drive works but going forward it does not...After sitting there for a while backing up, i manged to get the front to lock back in again and it seemed to be fine down the road. I noticed this problem last time I was plowing but it seemed to come around after the first time I switched off the AWD and shut it down (it was also -40 out) so I thought she was just flat out cold. Any ideas? Checked fluid level, fine....checked omhs @ the harness and they are within the range the book states..could this be a warped armature plate? Like I said...works every time in reverse...just hit and miss all of a sudden going forward...
Old Jan 25, 2010 | 05:01 PM
Old Polaris Tech...what do you think? Armature plate or going bad roller cage?
Old Jan 25, 2010 | 05:58 PM
If your going in there replace the armature plate and check cage for cracks and wear. OPT
Old Jan 26, 2010 | 07:46 PM
Does anyone know the part numbers for the John Deere parts? Would rather replace with metal then plastic...Thanks
Old Jan 28, 2010 | 07:44 AM
Kerbbirds's Avatar
John deer parts are- Roller Kit #MIA10666
Cage Kit #MIA10667
Seal Kit #MIA10654
Old Jan 29, 2010 | 12:19 AM
justrobb's Avatar
i have an 05 sportsman 400 are the parts the same to fix my front diff awd problems
Old Jan 29, 2010 | 07:09 AM
Kerbbirds's Avatar
Yes , anything with the newer front diff instead of hubs, dont know about the 550 and 850 , they might be different.
neilbedwell
Nov 10, 2018 11:02 AM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
yellowpolaris
Jun 21, 2015 11:13 AM
