Honda Recon choke cable
Old Jan 25, 2010 | 11:57 AM
Skidplatebob's Avatar
Default Honda Recon choke cable
The cable will not stay where i put it when starting. Is this a problem with the cable (worn) or where it attaches to the carb?
Old Jan 25, 2010 | 03:29 PM
ddrumman2004's Avatar
If not mistaken, there is a plastic hex nut under the rubber cover on the pull end of the choke cable. Pull it back and tighten the nut a little until the cable stays in position when you pull it out.
I had the same problem with an 05 Rancher I used to own and I was told of this fix several years ago.
Old Jan 25, 2010 | 03:48 PM
jawbone's Avatar
hey. i have a 06 honda recon 250. every gear works but 5th. when i shift into 5th. it feels like neutral. help!!!
Old Jan 25, 2010 | 03:52 PM
Thanks, I will try that.
GregM
Mar 6, 2018 06:53 AM
cornermike
Jul 30, 2015 06:37 AM
ghost civic
Jul 27, 2015 03:15 AM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
