350 Foreman DUMPING fuel...help!
Old Feb 2, 2010 | 06:26 PM
TheRiverHawk's Avatar
Default 350 Foreman DUMPING fuel...help!
Went to start my 1988 350D this afternoon. Uncustomarily, it wouldn't start at first. Then it kicked in but sounded a little rough. My friend, though, noticed fuel POURING out of what looks like an overflow tube. It starts doing this the second I turn the key on. It's almost as if the fuel pump is in reverse. Any ideas as to what this is?
I'm just a poor guy working in youth ministry. So any help I can get to avoid spending too much $$ is helpful!
Thanks!!!
Old Feb 2, 2010 | 06:38 PM
HeftyLefty's Avatar
The carb float is stuck. Run some SeaFoam in the gas, it may clean it out.
Old Feb 10, 2010 | 03:06 AM
Tried the Seafoam. Still dumping fuel. How difficult will it be to replace the float? Tear the carb apart?
Old Feb 10, 2010 | 03:35 AM
aaronrkelly's Avatar
Well you can try tapping on the fuel bowl with something like a screw driver - might break it loose.
If not your going to have to take it apart and have a look inside. Im not familiar with the exact carb in question but usually removing the bowl is a simple job.....in some cases requiring the removal of a metal wire or clip.....or merely a single screw. Your looking to get into the round part of the bottom of the carb....take a look and see if you can get into it.
Old Feb 10, 2010 | 04:27 AM
HondaMechanic's Avatar
You'll have to remove the carb , remove the 4 screws that hold the float bowl on .. Then check the float and inlet needle ..
Here is an exploded view of the TRX350D carb , It is a little different than most other Honda ATV carbs in that it uses a mechanical slide instead of a vacuum slide...
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
mark23
Oct 1, 2015 09:57 AM
highwayman
Sep 19, 2015 12:59 PM
patrick.oc123
Sep 15, 2015 02:45 PM
