need some help 2002 polaris scrambler 90
Old Feb 5, 2010 | 04:03 PM
pap paw's Avatar
Default need some help 2002 polaris scrambler 90
working on grand sons atv could someone tell me how the electric choke works? i tried to buy a service manual but clymer says they dont have one for this size. thank you.
Old Feb 6, 2010 | 09:01 AM
LT80's Avatar
LT80 Expert
From what I hear, they don't work.
Clean it up and lubricate and see what happens.
Old Feb 9, 2010 | 12:27 PM
HASBEENTTDUNER's Avatar
I have the same problem with a 2001 that I picked up for my son. The auto choke doesn't work but the carb works perfect otherwise. I have learned the thumbchoke method and it has worked perfect so far. You can get a new factory carb for a good price on ebay but the thumbchoke method has worked so well I am going to wait untill I get a better carb down the road.
The Thumbchoke Method.
Lock the parking brake and turn the key on.
Kneel down by the left front tire facing the quad.
With your right hand reach around under the tank area and forward and you will find a aprox 1" tube that goes straight up from the airbox. This is the airbox intake.
Cover the intake tube with your thumb.
Now reach up by your ear with your left hand and start it up.
Slowly move your thumb to let in more air as it warms up.
You will probably only have to do this each morning most of the time,but I am a west coaster.
The only drawback I have seen is that you will get a little fuel mist blowback into the airbox. It may drip a little but this will get you going untill you fix the problem. What is the problem is a good question. The new factory ebay carb has all of the carb mounted auto choke up to and including the connector that plugs into the wiring harness. If the problem we are having is above that then you just waisted your cash. Pick up a good carb that has a manual choke **** right on it and away you go. What carb is a question that I cannont answer at this time but I am sure others on the boards can.
I hope this helps you out for now.
Old Feb 9, 2010 | 03:16 PM
pap paw's Avatar
thanks i will see what happens.
Old Feb 27, 2010 | 01:19 AM
brianpowell's Avatar
Default its not a choke
electric throttle control it shuts down the atv in the event of a stuck throttle i thought it was a choke to found the owners at polaris after i joined hpe this helps
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
