250ex Sportrax clutch slip
Old Feb 6, 2010 | 09:44 AM
metal249's Avatar
Default 250ex Sportrax clutch slip
I have a 2003 Honda TRX250 Sportrax with a centrifugal clutch. The crankcase was filled with gas via a stuck float valve and bad design. The quad was not operated with this gasoline in the crank, but it did sit for about 2 days, before the gas was flushed out of it. The clutch is located inside the crank on this quad. When the quad was first ran after all this, I noticed a little clutch slip. I kept driving it hoping that the clutch would grab better once the fresh oil soaked in more, but it just keeps slipping more. Could the gas have ruined my clutch? How hard would it be to replace the centrifugal clutch? I am supposed to go riding/camping today and I wont get a chance to again for a while, so any thoughts on this would be great help.
Old Feb 15, 2010 | 04:40 PM
honkaw's Avatar
Well it's probaly to late for you to go riding with your buddies now ,but what kind of oil did you put back in your crankcase after draining out the gas laden oil? If it was synthetic then that may cause the problem your describing, Hope this is all it is Iv'e never changed a clutch on one of these but if the oil change dosen't help and you do decide to work on it there are some good exploded view prints at cyclepartsnation.com and if you have to by any parts they are the best.
Old Feb 26, 2010 | 12:56 AM
alalicious1's Avatar
well i would have to say that the oil is the problem if it is synthetic. also, changing the springs and clutch plates is a very difficult job. honda has a great design but everything has to be done carefully. i race my trx250 and i bought performance clutch springs and steel plates. i have had no problems with the clutch since i bought it in 2003.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
