carb question?
Old Feb 7, 2010 | 09:53 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Default carb question?
I just picked up 98 trx 300 4x4 and was going through it to make sure everything was in order. When I was adjusting the idle I notice on the left side (driver side) of the bowl there is a ****/screw that looks similar to the idle screw. What is this?
Old Feb 8, 2010 | 11:23 AM
hatchet rider's Avatar
not 100% but sounds like the air intake adjustment for the carb.
Old Feb 8, 2010 | 05:31 PM
HondaMechanic's Avatar
Are you looking at the primer ..
Old Feb 8, 2010 | 06:37 PM
712jared's Avatar
it could be a drain screw for the gas
Old Feb 9, 2010 | 12:14 AM
well today I had a little more time to look things over and took a closer look at the **** if you will. It does'nt screw in or out, it just looks like a push pull **** with a retainer clip holding it on. It sits almost at the bottom of the bowl on the side. I'm wondering if it's not a drain for the bowl. I'm a popo guy myself and have never worked on hondas but I came across this for $1000 in good condition. I picked it up for my baby brother whos finally home for good from Iraq. I've got it running like a dream so I don't think the **** has anything to do with idle or a/f mixture. I tried pulling it but it did'nt want to move. I'm going to leave it alone since the quad is running nearly perfect.
Old Feb 9, 2010 | 07:23 AM
zitaron's Avatar
you are looking at the cold-start primer........ in cold weather just give it 3 or 4 pushes so as to ease starting
Old Feb 9, 2010 | 01:21 PM
Thanks, that makes more since to me than anything I've come up with.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
