cam question
Old Feb 8, 2010 | 06:56 PM
712jared's Avatar
Default cam question
hi i recently bought a different cam for my honda atc 70 that has more lift and duration. just wondering if any one else has put a different than stock race cam in there 3 or 4 wheeler and if so what kind of difference did it make? this is the one i am putting in dont know what all the numbers mean but they look good. any replys would be appreciated
* !! NOTE !! (THIS CAM MUST BE USED WITH STOCK HONDA VALVES) OR AT LEAST CHECK TO MAKE SURE THE AFTERMARKET VALVES CLEAR EACH OTHER WHEN THEY PASS EACH OTHER... (YOU CAN GRIND OFF SOME OF THE VALVE'S OUTTER OD SO THEY DO CLEAR IF NEEDED)
SETTING THE VALVE CLEARANCE AT .003" WILL HELP WITH THE VALVE CLEARANCE IF YOUR USING AFTERMARKET VALVES
THIS IS AS BIG OF CAM AS WILL FIT IN THE OLD TYPE HEADS
IT HAS SOME LIFT OVER THE STOCK CAM, BUT TONS OF DURATION
THIS IS THE MOST RADICAL CAM MADE FOR THE OLD TYPE HONDA HEADS
THIS CAM HAS 6MM OF LIFT.
Camshaft Calculations - Lobe Center / Duration AT .050" VALVE LASH
THE VALVE LASH IS MORE FOR CARS AND REALLY DON'T GIVE A
TRUE CYCLE READING,, BUT THATS JUST HOW IT'S DONE.
THE LASH IS ONLY .0025" ON THE BIKES COMPAIRED TO .050" ???
THIS CAM has an Overlap of 40.00 degrees and has an
Intake Duration of 255.00 degrees. The Exhaust Duration is
265.00 degrees. The Inlet Cam has an Installed Centerline
of 102.50 degrees ATDC. The exhaust cam has an Installed
Centerline of 117.50 degrees BTDC.
LIFT IS 6MM
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
