Need Help
Old Feb 9, 2010 | 08:32 AM
roughriden's Avatar
Default Need Help
Fuse keeps blowing in my 2004 400ex. It works fine untill i turn my lights on then everything goes dim. Dim lights work but brights dont turn on. As soon as i shut my ride off after turning on the lights it blows the 15A fuse everytime. Shortage in the wirings? Where?
Old Feb 9, 2010 | 09:03 AM
scootergptx's Avatar
Supersock
Hired Gun!
What kind of voltage are you getting out of the battery before you turn on the lights, then after? Does it start up fine afterwards?
It does sound like you may have a short, but also like you're not enough juice too.
Don't have your model, but I'd start checking wires under the hood by the headlight to see if maybe one has rubbed of the insulation.
Hopefully you'll get someone who's had a little more experience to reply with a more accurate diagnosis.
Old Feb 9, 2010 | 10:07 AM
roughriden's Avatar
Well thanks for ur help ne way! it is a brand new battery but if i dont turn my lights on the fourwheeler will run fine.
Old Feb 9, 2010 | 10:54 AM
Supersock
Hired Gun!
Almost sounds like a bad stator if it's dimming the lights like that. But the blowing the fuse part has me scratching my head.
Old Feb 9, 2010 | 12:50 PM
roughriden's Avatar
Thank you for ur help. Went and bought some new fuses and tried that rode it down the road and everything worked fine. i appreciate u tryin to help me.
Old Feb 9, 2010 | 01:17 PM
voodoo574's Avatar
Sounds like a short up near the steering head. It's a pain in the a** but undo your wire loom and start looking at wires. You didn't say if the fuse blew if you left your lights on as you shut off your machine. And are you shutting it off at the thumb switch or the key?
Old Feb 10, 2010 | 02:21 PM
roughriden's Avatar
I fixed the problem thank u tho!!
Old Feb 10, 2010 | 02:55 PM
voodoo574's Avatar
So what was the problem? Don't keep us hanging.
Old Feb 11, 2010 | 04:30 PM
roughriden's Avatar
Lol. I must have been puttin old or bad fuses in it because they kept popin so i went and bought some new ones the the store and put one in it and havent had ne trouble with it since. havent rode much but did the things that kept blowing the fuses and it works fine now.
Old Feb 11, 2010 | 09:36 PM
voodoo574's Avatar
Gotta love it when it's the easy stuff.
