CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
Ds650 help hurry
Old Feb 11, 2010 | 10:21 PM
slater25's Avatar
Default Ds650 help hurry
In the wire harnes a yellow wire comes out of the harness along with what I think is the temp wire that plugs in to the engine. I have know idea what or where the yellow goes because the end is cut off.
On the stator cover there is a hose that plugs in at the bottom and runs up I guess where dose the top of the hose plug in ?
On the main oil hose from the tank to the block where it meets the block their is a smaller hose that is long, where dose it go?
Old Feb 18, 2010 | 09:41 PM
terrygs28's Avatar
There are a few yellow wires on the DS 3 yellow wires come out of the Stator which runs to the Rectifier under the seat. there are wires for the Temp sensor and for the Fan switch next to the temp light switch one is yellow on my 2000 DS
The hose on the bottom of the stator just goes straight up by the gas tank and plugs into the snorkle tube.
The little hose on top of the engine on my 2003 DS goes to the top of the valve cover.
I hope this helps
Old Feb 20, 2010 | 09:57 AM
slater25's Avatar
Default cool thanks
The wire that Im haveing trouble with has something to do with the neutral because when I ground the wire the green neutral light comes on. I need to find where this wire goes. Do you know what type of main jet is in the ds 650 Is a short hex or a long hex or what is it?
Old Feb 20, 2010 | 12:47 PM
hsr-tm45s's Avatar
the neutral wire is yellow with a brown strip it screws in just below the oil filter and front sproket cover i have a 2000 ds and it take a 5.5 mm scoket .
Old Feb 20, 2010 | 01:00 PM
slater25's Avatar
oh okay, the wire was cut about half way so I had know idea. Dose the wire need a specail end to mount into the hole by the sproket? Im going to half to add wire to make it to the hole but dont have a clue on what to do onces its there? Do you know what kind of main jet is in the carb ? is it round or Hex shape?
Old Feb 20, 2010 | 01:08 PM
hsr-tm45s's Avatar
just a small wire eyelet with a bolt to tighten it to mortor. if it is a stock carb the main jet is round.
Old Feb 20, 2010 | 11:40 PM
slater25's Avatar
cool you have been a great help, my lights are not working but my rpm gage is. I seen I had a blow fuse so I change it and now they still dont work??Help
MRDS650
Feb 22, 2026 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
minehunter
Apr 23, 2001 01:37 AM
ScoobyDFW
Jun 13, 2000 11:33 AM
