do i need to replace
Old Feb 12, 2010 | 02:37 PM
blevinsbulldog's Avatar
Default do i need to replace
im planning on cleaning the carb on my boys Kfx 80 & was wondering if i need to replace any seal or gasket when i put it back on.
Old Feb 16, 2010 | 12:26 PM
rjdad's Avatar
I would say that you would have to since if you try and reuse the old gaskets it will not properly seal and you will have leaks. You might get away with using gasket sealer as I used some when I cleaned my 1984 Honda ATC and no leaks observed. See if some of the experts will chime in on your question
Old Feb 16, 2010 | 02:55 PM
Scooter86's Avatar
Knows Old ATV Questions!
While I can't say that i have that carb apart, most have a reusable gasket. Just be careful not to tear it if the carb halves are stuck together and you should be fine.
Old Feb 17, 2010 | 09:04 AM
LT80's Avatar
LT80 Expert
no.
Old Feb 17, 2010 | 11:56 AM
rjdad's Avatar
LT80,
No to what? Set us straight here.
Old Feb 18, 2010 | 08:01 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
While i would never speak for LT80....Im pretty sure he is saying no, the gaskets and or o-rings will not need to be replaced.. Not sure about this carb, but if there are any rubber items in it..keep carb cleaner away from them or they will grow to a very useless size..
Old Feb 18, 2010 | 08:49 AM
LT80's Avatar
LT80 Expert
Sorry fellas..MWQ is correct.
I have run into a ripped bowl gasket but it's mighty rare.
Old Feb 18, 2010 | 10:05 AM
rjdad's Avatar
Thanks mywifesquad and LT80...I'm learning new things all the time.
Old Feb 19, 2010 | 04:40 PM
ok, got the carb off & most of the way apart. do i need to remove the main air jet 2 & the neddle jet to boil my carb & if so, how in the world do i remove them?
toonces
Aug 5, 2015 05:55 PM
U2OFlyer
Aug 5, 2015 12:46 PM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
