Kaw-Prairie 650 with no LED screen display
Old Feb 13, 2010 | 12:07 AM
re-searcher's Avatar
Question Kaw-Prairie 650 with no LED screen display
I have a 2003 Kawasaki Prairie 650 with a problem with the LED read out on the dash board. The fuse is good, but when turned on or running there is no speedometer, odometer or fuel guage reading at all. The only light that is working is the neutral light. Any suggestions as to what I should look for to fix this issue? Thanks for your help.
Old Feb 13, 2010 | 01:06 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
when the LED goes out on my Arctic Cat, i just disconnect the battery and reconnect it after a few minutes and it resets it...don't know if that's the problem here, but it costs nothing to try
Old Feb 14, 2010 | 12:48 AM
Default Nice Try, but didn't work
Thanks for the suggestion. I disconnected the battery like you suggested, as well as all the wire leads, then reconnected everything. Still nothing. As I said before the neutral light comes on and I just realized that when I turn the lights on the backlight comes on the screen (for night viewing), but I still have no read out of the guages. Still searching. Please someone...help! Thanks!
Old May 25, 2015 | 07:26 AM
bodatiouskid's Avatar
My 02 650 Prairie just started doing the same thing.Have neutral&reverse lights & thats it.
Old May 25, 2015 | 04:51 PM
newfiebullet's Avatar
Just fixed that 20 mins ago..for me one of the plugs on the right side of the airbox was undone..plugged back tight way to go..think it was closest to the front
Old May 27, 2015 | 05:14 PM
Near the starter solenoid?
Old Jun 14, 2015 | 12:57 PM
Under the panel just below the throttle..on the right side of the airbox...where a gas tank would normally be
Old Oct 13, 2015 | 09:04 PM
nsKawiRider's Avatar
I had this and I had an aftermarket cdi box so i bypassed the belt sensor and it's still running 3 years later..
Old Oct 14, 2021 | 08:16 PM
Fletch11!'s Avatar
Default 02 prarie guage problem
Help appreciated!! Have a 02 650 PRARIE and as others have experienced, I only have Neutral, Reverse and Backlight. No other data registering. Is there a fix? Thank you for your help. Yes I know old bike but is very low hours and 1 owner… not a suarine 🙂
95wolv
Sep 27, 2024 12:00 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bigtwin700
Sep 10, 2015 10:46 PM
rawbdiggity
Sep 7, 2015 12:05 PM
