200cc Gio Beast stalls when you give it gas
Old Feb 13, 2010 | 11:31 AM
jonzo22's Avatar
Unhappy 200cc Gio Beast stalls when you give it gas
I have a Gio Beast 200cc, i recently posted here about electrical problems with it. I can get it to idle, but when i give it some gas it stalls almost right away depending on how much i give it. I tried driving it, i can hardly rev it up and it dies? I dont know what to do?
Old Feb 14, 2010 | 08:54 AM
LT80's Avatar
LT80 Expert
Clean the carb. A jet is plugged.
Old Mar 5, 2010 | 06:44 PM
jonzo22's Avatar
ok, after cleaning the carb painstakingly accurate and carefully, using carb cleaner and blowing it all out with a air hose, also using a small wire to clean the jets, IT STILL DOESNT WORK. It does start now and idles a bit better, but it takes a while to start and i have to choke it for a few minutes or else it will die, and you have to be careful when you give it gas or it dies. TRUST ME, i spent about 6 hours trying to figure out ways to clean that carb perfectly and i cleaned every part of it. Then i did it again. Im pretty much ready to smash the whole quad and throw it in the dump. Anyone have any ideas what to do? Basically it can start after a while but if you give it the wrong amount of gas, it bogs down and stalls.
Old Jun 30, 2010 | 11:55 AM
jonzo22's Avatar
Exclamation Fixed
The problem was that it needed clean new gas. I just drained the old gas and put in some new stuff and it actually runs just fine. All the info on this site about cleaning the carb and jets and things, huge waste of time. I spent hours and hours trying to make my carb more clean only to find out that i just needed new gas in the quad. Thanks for nothing everyone.
Old Jun 30, 2010 | 03:30 PM
kellysautosport's Avatar
well i guess i need to try that method. cause i spent 2 days cleaning the hell out of my carb and only thing changed was how it idles. so ill try the new gas thing (although it already had new gas in it) and if that dont work. off to a new carb
Pehter
Oct 3, 2024 11:00 PM
Sassinm1
Sep 30, 2015 04:23 AM
Sep 30, 2015 01:37 AM
woodthings
Sep 25, 2015 05:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
