06 scrambler 500 three wheel drive problem
Old Feb 14, 2010 | 07:37 PM
06 scrambler's Avatar
Default 06 scrambler 500 three wheel drive problem
i have a 06 scrambler 500 that i had to replace the front bearings in one side, i put the new ones in and now that wheel will not ingadge when i put it in 4 wheel drive. do i have to replace the clutch looking thing to ? theres a wire that comes out of the strut could that be bad too ?
Old Feb 15, 2010 | 04:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you put the correct hub fluid in? is the wires going to the assembly damaged or unhoked as these are what powers it.
Old Feb 15, 2010 | 08:12 AM
MECHANIKE's Avatar
yeah like stendori said make sure the right fluid + the correct torque is important.
Old Feb 15, 2010 | 09:59 PM
ramman67's Avatar
Default make sure the
make sure the armature plates 3 little ears are engaged in to the back of hillard clutch and that its seated against the armature sleeve.
Old Feb 15, 2010 | 10:00 PM
i dont want to sound like a dumb a$$. but hub fluid ? i thought you just put grease in there were the bearings are ? i have had both front hubs off a couple times before just to replace the old grease the scramblers arent very water tight .oh and the wire is hoked up.
Old Feb 15, 2010 | 10:07 PM
ramman67's Avatar
Default hub
you need to clean all the grease out and put the proper hub fluid in both hubs.
Old Feb 15, 2010 | 10:13 PM
MECHANIKE's Avatar
use brake or carb cleaner to clean ALL the grease outta there,torque bearings to 12 foot lbs.put type f trans fluid in.then let drain to 3:00 or 9:00 position,put screw back in.
Old Feb 15, 2010 | 10:15 PM
oh wow now i do feel like a dumb a$$ !!! i will give that a try and see what happens. thanks.
Old Feb 16, 2010 | 08:06 AM
TLC's Avatar
TLC
Here is how the AWD hubs goes together.http://www.atvtime.com/phpBB2/viewto...003&pc_t=12521
Old Feb 16, 2010 | 07:56 PM
Wow that is nice !!!! I have no more questions. Thanks alot tlc.
