04 Rancher 400 AT can't shift lever into Drive
Old Feb 16, 2010 | 09:00 AM
tbarry09's Avatar
Default 04 Rancher 400 AT can't shift lever into Drive
Hello, my shift lever was difficult to shift into Drive without a grinding gears sound. If I had it it Reverse it was almost impossible to shift out of Reverse to Neutral then into Drive without shutting off the engine. Now it does not want to shift into Drive at all. Is there a linkage adjustment for this, or the angle shaft sensor, or is this a bigger problem. Thanks.
Old Feb 16, 2010 | 03:27 PM
HondaMechanic's Avatar
The shaft for the sub-transmission corrodes where it passes thru the aluminum case ..
Here is where it will seize ..
Old Feb 16, 2010 | 04:08 PM
polymite's Avatar
Idle speed could be to high causing hard shifting and grinding.
Old Feb 16, 2010 | 10:57 PM
tbarry09's Avatar
The idle speed is high at times. I will try to correct that. It fluctuates when in neutral trying to put in Drive. Will also check the shaft where it enters the aluminum housing for corrosion. Thanks for your help.
mbkirk
Aug 14, 2015 08:20 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
