Engine smoking
Old Feb 18, 2010 | 08:54 PM
itsjustagreat1's Avatar
Default Engine smoking
I was wondering if anyone could give me any ideas why my 1981 klt 200 is smoking when you rev it. It looks like a blue/grey smoke most of the time. It is not a fog of smoke but if you run it in the shop, after a few min. you can see it in the air. It has good compression 150psi. The sparkplug doesn't look gunked up or oil covered. I adjusted the valves to spec and cleaned carb again. Is there any additive that I could put in it to stop it from smoking? Will it hurt if I just run it that way? Thanks, Preston
Old Feb 19, 2010 | 08:44 PM
notmyday's Avatar
if u got that good compression it is more than likely valve seals keep oil in it and it will be fine.
Old Feb 19, 2010 | 08:51 PM
notmyday's Avatar
with it being that old if it isnt seals. the valve guids could be worn. but either way keep oil in it it should be fine until it gets worse. then time for top end rebuild which is pretty cheap to do.if you have a compression tester with a quick diconnect on it you can close both valves and put pressure in spark plug hole. remove the valve springs and put new seals on. just keep compression on the cylinder until springs r back on so you dont drop a valve.
Old Feb 21, 2010 | 01:33 PM
Thanks for the info, I really appreciate it!
dirt ryder
Sep 27, 2015 09:22 PM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Dirtbikemike1
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
