Upgrade Battery
Old Feb 21, 2010 | 09:03 AM
HEMIsphere's Avatar
Default Upgrade Battery
I am wondering if anyone has upgraded their battery and if they did with what kind? I have the stock battery and there have been a few time while plowing at night with the lights on, winch going and the fan going the battery indicator would start to flash. The quad is kept in a garage where it never gets below 35 degrees. I was hoping that Optima batteries made a battery but it does not look like it. Just curious and thanks for the feedback.
Shane
Old Feb 21, 2010 | 09:19 AM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Odyssey batteries have been known to be very good, if not, the best you can get.
Old Feb 21, 2010 | 10:28 AM
JCDEYO25's Avatar
Yup I use a Odyssey also along with a battery tender...
John
Old Feb 21, 2010 | 10:41 AM
700 sportsman's Avatar
When my stock battery goes, I'll be going with an oddessey
Old Feb 21, 2010 | 02:52 PM
HEMIsphere's Avatar
Thank you very much it seems like Odyssey batteries are the way to go, I will check them out.
Old Feb 21, 2010 | 05:53 PM
1882's Avatar
Runs a Full 730 Race Build!
I've had one in a DS650 for over six years with no issues.
Old Feb 21, 2010 | 05:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pretty much it sounds like your overloading the charging system on no matter what battery you put in it. imo
Old Feb 21, 2010 | 08:23 PM
HEMIsphere's Avatar
Stendori,
While you may be correct then there must be something wrong, I am not doing anything different from what I am sure 70% of other riders are doing. I am just plowing in at night when I have had this issue. I put a charger on the battery and according to the charger I have it tells me that the battery is "sulfated" and won't fully charge anymore. I guess I am hoping that the Odyssey battery is closer to a deep cycle battery that can handle being drained and then be able to be charged. The stock one was not able to do this.
Old Feb 21, 2010 | 10:00 PM
bentarrow's Avatar
First Things First!
If you battery charger has a desulfate or recondition mode that battery might last until next winter without a problem depending on it's age.
Old Feb 22, 2010 | 05:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by HEMIsphere
Stendori,
the biggest thing like any other battery the more it's used(charged,decharged) it does where on the battieries life for sure. i wasn't meaning to single you or anybody out in saying your running to many power draining processes at once for the 500 watt max out put charging system to handle. i agree that i have heard good things about this oddessy batt and i'm sure it wouldn't hurt to have a better grade in it. imo
