2004 TRX 350TE Starter Question
Old Feb 24, 2010 | 07:46 AM
Cmarti's Avatar
Default 2004 TRX 350TE Starter Question
This Rancher has been great, but think starter is gone. Tested selenoid/relay and it is good. Brushes are good in starter, but will not turn.
When going to order a starter none of the OEM parts diagrams match the starter I have.
Mine has a hardwired harness, and the parts diagrams show a more traditional starter with a power post. I have a 2 hour round trip to the dealer, but it may be worth it to not order the wrong starter.
Any experience out there with these starters? Is there a diode or circut to check other than the starter relay/selenoid? Thanks with any help.
Old Feb 24, 2010 | 03:35 PM
HondaMechanic's Avatar
This is the starter that comes on every TRX350 ... If you have something different then someone geared something up...
Old Feb 24, 2010 | 04:45 PM
Cmarti's Avatar
Not it, I will go pull it and post a picture later tonight. The armature and brushes are on the shaft end.
Old Feb 25, 2010 | 08:09 AM
KNOWSALOT's Avatar
The Facility
I'm with hondamechanic,..I havent ever seen a starter motor like what you describe on a Rancher 350. In fact, they use the same starter brushes across the entire TRX line so I have no idea why you have something that is different.
Are you sure you aren't looking at the ES shift motor instead of the starter motor?
Old Feb 25, 2010 | 10:15 AM
Yes the shift control motor is what it will be , it is hardwired with approx. 2 foot wire with the coupler on the end ..
Old Feb 26, 2010 | 07:30 PM
Cmarti's Avatar
Is this a shift control motor? It has brushes and an armature, so we thought it was the starter. We are accepting of being called idiots!
Attached Thumbnails 2004 TRX 350TE Starter Question-201_2388.jpg   2004 TRX 350TE Starter Question-201_2389.jpg
Old Feb 26, 2010 | 08:25 PM
Yes that is the shift control motor ... The starter is at the rear under the airbox ..
Old Feb 27, 2010 | 08:51 AM
Cmarti's Avatar
Thanks! Lesson here, buy a book...I have one for all my other quads, bikes and cars, but this thing never needs worked on. I have done starters on three other bikes, and thought I knew what I was doing......that should have been my first clue.
Again, thank you.
ghost civic
Jan 15, 2020 07:43 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
